Looking for some info on what the advantage is to switching to the S7 spindle,and how it affects the handleing on the smack chassis? thanks in advance for any ideas or thoughts!
S7 spindle advantage
Doing just the spindle isn't the right thing to do. S7 is a complete front end, you can't just whip on a set of spindles and think you've got an S7 front end, it doesn't work that way."If racing were easy, everybody would do it."
#77 Leon "Slick" Sells
Partially true.Originally posted by F22 RAPTOR View PostDoing just the spindle isn't the right thing to do. S7 is a complete front end, you can't just whip on a set of spindles and think you've got an S7 front end, it doesn't work that way.
The left side control arm lengths and tie rod length are the same from the old stuff to the S7. Both spindles are are different. Both right side control arms are different and the right side tie rod is different.
Ride heights also change to 3.5" both sides with the S7 setup.
From what ive experienced ,Now im still pretty new to Late models, but it seems the S7 does free the car a bit it has been excellent on grippy and patchy tracks steers well, and on drier tracks seems very Right front dependent. If you can keep it way down on the nose it works well in slick too. If your smackdown doesn't steer confidently this deal works well for that. Ours is an '08 square smackdown. Just won $2500 saturday on a slick track so it can do slick too
The biggest difference I noticed was driveability. Prior to the S7, when the track was still fast, if I didn't get the car set in the corner just right I really had to fight it from the center off. For example, if I didn't get in quite hard enough and the car was to straight at the center of the corner, I would have to yank the wheel and stand on it to get it to turn again through the center.
If I make the same entry mistake with the S7 front end, I just give the wheel a little twist and on around she goes. Doesn't matter if I'm on the gas, on the brake, or rolling through the center.
I like my car a little straighter on entry than most which makes us good in the slick but was killing us when it was fast. The S7 helped that a bunch.
I've sense gotten a lot more aggressive in the heavy stuff and it is still very responsive to steering input.
