Engine trouble
  • lazermod3
    • Jan 2008
    • 1910
    #31
    Originally posted by DoubleD View Post
    Thanks Again for all the input guys. Engine just had a simple pan with screen in it. I do have alittle more info. This is a spec engine just as my last. The old engine had 60-65psi oil pressure with a 5-stage SCP pump. Put the same pump on the new motor and when i was @ builders when first fired it had right at 100 psi @ idle. I questioned about it , just got a " well its fresh just need to turn the pump down." Well forward several months ,builder still hasnt fixed it and after sitting in stands all summer, a buddy offered me his spare engine . Went and got my oil pump, cleaned it out, put it on borrowed engine....60-65 psi as soon as fired. Am i reading too much into this that builder just plain f**cked -up and had something too tight in the new one?
    Remember DoubleD;these professional so called engine builders can do no wrong!And if they do screw up,they won't admit to it.
    you just got greased
    http://www.goddardwarrior.net
    • dualdj1
      • Jun 2009
      • 654
      #32
      either something too tight or a blockage in the oil passage
