In Car Camara?
  • Sprint76
    • Aug 2008
    • 76
    Haven't broken a lens cover yet on the gopro case, but they do get chipped from the rocks. This solved the problem.
    • lazermod3
      • Jan 2008
      • 1910
      Contact Jody Shannon,operator of the DRC,he can steer you in the right direction.
      you just got greased
      http://www.goddardwarrior.net
        Any idea what Lucas uses for their on-board cameras on their televised deals?
        • latemodel86
          • May 2011
          • 163
          I'm 99% sure it's GoPro
          • 1fast1
            • Oct 2009
            • 50
            catch cam had it since 2000 great cam no problems great at night even under the car.
            • jr18
              • 87
              What is the best software to use too edit your video fo the go pro?
              • 1fast1
                • Oct 2009
                • 50
                what do you want for the catch cam does it work or just parts?
                • merc123
                  • 1261
                  All are GoPro that are on the cars. You can see them on some of the pictures and videos. They do not use the GoPro mounts though. They have a more ridgid mount and after breaking 3 of the roll bar mounts I'll probably get getting one like they use as well.
                  Web: http://www.t17.co
                  • merc123
                    • 1261
                    These are all of my videos shot with the GoPro:
                    The GoPro 2 (new one) has a WHOLE lot better video than the original, especially at night. I use the R5 setting for all of my shots.
                    • late96
                      • 581
                      Any more recomendations? Seems like mixed felling between contour and go-pro. Thanks
                      • racin6mod
                        • 2172
                        I was at wal mart getting a menory card and they hae a new system for 89.00 that is slimmer than my go pro and uses the same type mount.I like the go pro but it was a little hard to figure out at first.
                        • powerslide
                          • 2696
                          i know this is old but curious how many MB SD card most of you are using. We run 20-25 lap races but sometimes turn into a crash fest 30 plus minutes to finish up.
                          MERC123 did you ever find the other mounts? If so who/where did you get them.
                            I use a 16 GB card.
                            • Sprint76
                              • Aug 2008
                              • 76
                              I use a 16 GB card.
                              Same here. Should be good for about an hour at 720p.
                              Amazon is having a huge same in flash memory right now if you're looking for a card.
                              • merc123
                                • 1261
                                8 is bare minimum for a race. I use a 16 on mine but that was because I couldn't find any affordable 32's. I can usually get two races on a 16 GB card just in case I forget to delete the week's prior race.
                                I have found some other mounts and cases, but the cost of them weren't feasible ($199). Lucas Oil uses a certain kind of arm mount that I saw for I think ~$40. I just haven't bough it. It's not as easily removed like the GoPro roll bar mount because it uses hose clamps. If you pre-mount it, which I always do unless I rent my GoPro out, it shouldn't be a big deal though.
