What are most of you guys using aluminum or steel motor mounts on your aluminum motors ? Thx
Steel or aluminum motor mounts?
ive seen the aluminum ones twist an bend on a stock block super street car...white trash motorsports
I've seen to many aluminum mounts crack or twist. Been running steel mounts on aluminum motors for 10-12 years with no problems.(Was in the lightweight phase like everybody else back then and one thing for sure is lightweight is great but only if it works and doesn't fail)
I use aluminum because they will deform a lot more than steel when you get in a wreck. I would rather have the mount deform/crack than the engine block.
Never had a problem with cracking but maybe thats because I replace mine every 2 years or so. Aluminum has a lot shorter fatigue life than steel.
I'm sure it's happened, but whenever I've seen a hard hit, the engine mounts on the frame will bend/break before the bosses on the aluminum block break and thats why we have always run steel...
^ I do agree. And personally, I like to have a setup to have as strong of thermal connection as possible to the motor, so it can also act as a heatsink. Aluminum would do a better job than of steel.Originally posted by FlatTire View PostI use aluminum because they will deform a lot more than steel when you get in a wreck. I would rather have the need to buy motor mounts deform/crack than the engine block.
Never had a problem with cracking but maybe thats because I replace mine every 2 years or so. Aluminum has a lot shorter fatigue life than steel.Last edited by cswitch11; 08-05-2012, 01:39 AM.
