camshaft breaking!!!
  • neil7e
    • Sep 2011
    • 47
    had this happen twice in two years,the camshaft breaks by the distributer on a dry sump motor. Any other guys run into this and is there a cure?
  • perfconn
    • 3573
    Quite common,espically in flat tappet applications.Use the Comp Cam lobe lock core.Sometimes happens with roller cams if it is a standard sbchevy size cam core.In that case use the 8620 billet steel gold core.
    • neil7e
      • Sep 2011
      • 47
      thanks for the info!
      • perfconn
        • 3573
        Make sure your not coil binding the valve springs or floating the valves.Thats where the breakage starts.
