I'm looking for ride heights for the bottom of the frame rails to the floor ft and rear. the fronts like at the kick up and the rear at the ends of the frame rails, car just does not look right and the stub was bent at one time. any help would be great thanks
black ft end rocket
LF 3 5/8 RF 3 1/2 RR 6 1/8 the front is measured from bottom of frame rail to top of lower control arm. The RR is top of original welded TWM bird cage where the bolt gos thru to the bottom of the frame rail, I like to use a level on the RF lower and keep it level. This is right about the 3 1/2 ride height they call for. If the car is bent some where this shouldnt affect the front measurement areas at all unless its bent really bad. Otherwise call Anthony at Rocket and get some measurements to see where your bent at.
