5th coil questions!
  • moosie34
    • 36
    5th coil questions!
    Alright so I'm having trouble with my 5th coil spring jumping off the shock. Now my questions are what is the correct way to set you 5th coil and why is it jumping off! Thanks
    Myles moos
    MYLES MOOS RACING
    #20 Valvoline POWERED
  • joedoozer
    • 745
    Jumping off? You mean coming unseated from the hat? The spring should be preloaded 4 turns when the car is sitting at ride height. And the spring should be zip tied to the hat.
    I use a hose clamp above the coilover nut to keep it from backing off. I don't like those little set screws. Always full of mud, they can strip out. Or someone helping me doesn't know its there and turns the nut buggering up the threads.
    Crew Chief "Tip of the day":
