Should my bird cage be in line with my chassis brackets? I looked at my bar angle from bird cage to the chassis and the bars angle in towards the right side of the car, do yall think this is correct?
Left Rear Bird Cage
I think that what you really need to be concerned with is the "trailing arm toe" when the LR is at full droop. At ride height, the arms will have to be angled inward pretty good in order to not end up "toed out" at droop.. I think that you need to make sure that the arms are pointed exactly straight, or slightly inward at full droop... the reason I say "I think" so much in this reply is because I don't feel super knowledgable on the subject, just trying to help....
Sorry, I read your post wrong, I was thinking of the RR angles....If your LR bars are angled in alot at static ride height, they will end up angled in even more in droop.. I would contact your chassis manufacturer, they will want to see the arms at a certain angle for a reason, and your question is very valid...
