2002 grt no grip center off?
  • mignum
    • Sep 2010
    • 140
    450LF,400RF,225's rear -J-bar 8.75" on frame and second notch from bottom on pinion,and 400lb spring on fifth coil. On a 56 racer RR tire. Percentages are Left 53%,REAR 54.5% ,CROSS 51% , Bite 110lbs. Bars on left side LLR is bottom hole UL is in top hole and RRU is in top hole ,RRL is in the third hole from the bottom,15 gal fuel , air pressures are LF 9,RF 10.5,LR 5,RR 9 this car has the old brackets in one inch increments.
  • lcpestka
    • Aug 2007
    • 144
    LF=550
    RF=350 if heavy and 325 if slick
    LR=200
    RR=250
    and drop your RR top Bar one hole other wise looks good
    • mignum
      • Sep 2010
      • 140
      Thanks for the help, i will try that after i get my car back together.
      • mignum
        • Sep 2010
        • 140
        Lower Control Arms
        Does anybody know if i can switch to the one piece lower control arms on my 2002 GRT, right now i have the hockey stick deal, the lowers are 17 5/8" and upper is 8 1/4" i think? Its the narrow front end.
        • crate late
          • Jun 2009
          • 137
          Sure you can switch them, but I wouldn't just switch for no reason or until I bent one.
          • mignum
            • Sep 2010
            • 140
            I bent upper and lower sat. night.
            • grt74
              • Jul 2009
              • 1380
              i would look at the 5th coil spring 400 sounds like to much unless its really hooked up,also i would run a little more air in the right front,we have had alot of sucess with a 02 car were still running it and beating alot of newer cars (i love it,it just kills them)
              • mignum
                • Sep 2010
                • 140
                Thanks i thought the same thing on the 5th but someone talked me into the 400, you think maybe a 325 or 350? maybe 12lb in right front?
                • grt74
                  • Jul 2009
                  • 1380
                  if its a crate you might get away with even softer but if a super you should be close,hoosier 12 in the rf sounds like a good starting spot,pm me with your setup and i can tell you some things that have worked for us,bar lengths,angles ect
                  • mickeyd18
                    • Apr 2012
                    • 58
                    i run a 02 also and start with 8lb LF 12 Rf 5 to 6 on LR 9 to 10 on RR check your 5th coil make sure its on a 36in center to center,it helped mine a bunch i run a 500 lf spring 350 rf and have been as low as 300 on a slick track, i also like to see what other guys are doing with these older cars they seem to be a decent chassie for the year
                    i belive my fifth arm has a 325lb without looking at my notes
                    • mignum
                      • Sep 2010
                      • 140
                      Thanks for the setup help guys my lift bar is on 32" with the 400lb spring, i think softer here will help, and maybe going to the 36" setting, i have been making only one adjustment at a time so i know what does what.
