Soft right front spring
  • HOTDOG
    • Feb 2010
    • 39
    When setting ride Ht and bite should I have the RF adjuster turned so far down I can't turn it anymore or should I pickup it more with LF spring and turn more in LR. RF seems way to stiff with all the turn in it. 400 LBS spring.
  • dualdj1
    • Jun 2009
    • 654
    if you crank in more LF and LR, then you can potentially change your cross % depending on turns you put in. If you are setting ride height, you set your fronts together, go back and forth between them until both are set at proper height. then adjust your rears for cross % as best as possible. Recheck fronts after setting rears.
    edit: updated as my brain wasn't working.
    • 4bangerhotrod
      • 374
      how are you gaining LS% just by adjusting the lf and lr adjusters
      • stevo
        • Jun 2008
        • 622
        Can't change % with coilovers, have to move weight to do that.If your rears wheels weigh 1000 lbs and screw coilovers down a ft.same wheel weight.
        • gatorade
          • 76
          so if i go from 60lbs of bite to 180lbs of bite by applying turns, that i wont adjust the left side percent in the car? I agree that big swings in percents cant happen with just turns, but i know for a fact you can create 1.5% swings without changing weight position...
          A 400lbs spring in the rf sounds awfully big to have preloaded a ton to make it to stiff so i would look into what you are doing with your left rear, make sure it is preloaded, you want to create your bite with your left rear spring
          • Egoracing
            • 4852
            Any gain on the LR would add RF and come of off the LF and RR, You can not change weight %'s without changing weight location. You can put stiffer springs in and crank the LR and RF down until the LF and RR were off of the ground and the left side and rear %'s would still be the same.
            • WV_Race_Fan
              • 497
              You absolutely do effect weight % by adjusting the spring pre-load/ride height and spring rates. And depending on what you do, determines how and what.... It may not make a noticable or significant change in the % that you see when making larger changes such as sliding over the battery, or moving a piece of ballast, but it does change it.
              To add to what 4banger said. If you simply raise the LF and LR up (evenly), it will not add LS%, it will simply raise the LS ride height. But it will effect rake in the J-Bar, side to side, and shock/spring angle which has a minute change in spring rate..
              Later,
              WV Race Fan
              • stockcar5
                • 1289
                ego is right you can NOT change left or rear % without moving lead. you can only change your cross % and lr bite with weight jacks.
                • steelkiwi75
                  • 366
                  so the only way to go from 55% rear to 54% is to move weight, not by adjusting coilovers?
                  • zeroracing
                    • 1014
                    Correct, you can only change left or rear % by physically moving weight in the car, you cannot adjust coil overs to adjust left or rear percent. Coil overs only change ride ht and cross weight or lr bite.
                    • stevo
                      • Jun 2008
                      • 622
                      Correct,i tried that once.
                      • sj valley dave
                        • 1016
                        If you guys use scales just look at the LS %...You can crank preload all around, but the LS% doesn't change...
                        • lovinlatemodels
                          • 486
                          Hot dog what size spring do you have in the RF I been down as low as 300 and still had room to adjust.
                          • HOTDOG
                            • Feb 2010
                            • 39
                            Spring
                            400 lbs RF 250 lbs LR with room to ajust on left rear.
                              If you are adjusting coilover nuts and seeing it change your left side and/or rear percentages, one of two things is happening:
                              1) your scales are junk
                              2) you're doing the math wrong
