Nonbeadlock weld wheel and hoosier tires any tricks to get them on the bead?
mounting tires
never had an issue... try going around the tire once with the bead breaker.. then spray a little WD-40 around the bead.. let it sit for a few minutes then go at it.. I do it that way with a few Valken Wheels we have.. also try and not move far around the tire each time you try and break it down.. That works sometimes too..
I think he is asking how to get them seated. we use dish washing liquid rubbing tire bead and wheel bead. Baby powder crazy as it sounds also works good . Aero brand wheels are the toughest ones to get seated they are a real pain in the a&& sometimes you just have to man up and air the crap out of them I hate it when they pop out had one today bounce off of floor about 6 in when it seated not fun.
I have some Valken's that are a bit tricky to get to pop. Takes a bit more air than the old worn out Welds I have (I'd guess around 30 psi).
I use soap and water of some sort. Also do the best you can to get the bead of the tire square to the bead on the rim. I've noticed if you get 3/4 of the tire to set right away, that last 1/4 is tough.
Also, take a short air hose, like 10'. Get yourself a chuck that stays on the valve stem, clip it on, then you can plug the hose in, or use a valve of some sort, and you're 10' away. Lots of tires are mounted every week with few consequences, but there have been plenty of people hurt or killed doing it too.Here's my little home on Youtube!
Home Page
http://www.AmickRacing.com
We have always used wd-40 never had a tire come off the wheel. But that don't mean we want this weekend.
I've used soap and water, purple power, PB blaster and WD-40. They all work. Haven't had one slip off the wheel.Web: http://www.t17.co
I made up a simple fitting in the shed one night its a steel valve cap drilled through and inserted into some air line with a hose clamp to hold it in plase. other end plugs straight into the compressor line and provides unrestricted airflow when you remove the valve from the stem and screw this baby on, plug it in get the bead posisioned and walk away a safe distance and wait for the beads to pop on, I always use detergent but always get a stubborn one now and then.
Detergent also fixes those annoying slow sidewall leaks, just coat detergent on the inside of the tyre and it blocks the holes up.
Cheers Brendon
One more thing I forgot, but had a stubborn tire this weekend to make me remember.
Hoosier says never go over 40 PSI to seat a bead. I don't go over 30. If it doesn't pop by 30 and I let it sit for a few minutes and still no seating, I let the air out and break the bead back down for the side that hasn't popped. Recoat with your choice lubricant then air it up. Sometimes you can get the back bead to seat completely then you can break the front bead down and re-try. The more square it is on the wheel the better it is.
I wound up breaking front and back down on this tire 3 times to get it to seat but never went over 30 PSI. Back popped at about 20 and front popped at 29. I also had to keep spraying the rim with PB blaster.Web: http://www.t17.co
