kse tandem pump
  • huckleberry_hound
    • 206
    kse tandem pump
    hooking up an older kse tandem pump,,,do u have to use the bypass on the pump or can u run a bypass back from fuel rail and plug the one on the pump off?
    • 2020
    You can just remove the fitting from the return line on the pump and put an AN plug in it and run a normal bypass regulator at the the back of the fuel log. It works but better then the pill bypass, IMO.
    I actually just fixed a car by doing this that had been fighting fuel issues for 4 months.
    • huckleberry_hound
      • 206
      Ok. Sounds good. Thanks
