Were running a 2011 black front car aluminum 800 hp engine car has all good components on it and well maintained The problem that were having is it seems to lack the forward drive to launch off the corner driver says its good going in but gets free at the later part of the middle and comming out of corner (wants to pull the back around not walk to the wall). I'm not sure if this is a case of actually being to tight in and misreading or over adjusting the car too much to try to get the drive in it. Here's what we've been running
550. LF. 275 RF.
200 LR. 250 RR.
300 5th coil on a gas Integra Ida 1/4 in preload
15 gal fuel
584 475
700 547
Left 55.6%
Rear 54.0%
Cross 50.9
153 lb LR
13 1/4 drop
Jbar 9 in at frame bottom of pinion plate right side
bars set to netural to scale
Integra Ida shocks
LR top 3 rd hole (short rod ). RR upper 3rd hole
LR lower 4th hole. RR lower 3rd hole
I've been running the LR adjuster nut down to the spring when it drys out along with dropping the Right upper down a hole and J bar at 9 in also shortend the right side bars 3 turns
We're running Hoosiers 1300 to 1450 range
I also took the "dummy shock" off to try it out some advise I was given but the car seems kinda lazy lifting up the LR
We're on mostly dusty dry dirty type tracks not with that glassy slick.
Any help or ideas would be appreciated thanks
550. LF. 275 RF.
200 LR. 250 RR.
15 gal fuel
584 475
700 547
Left 55.6%
Rear 54.0%
Cross 50.9
153 lb LR
13 1/4 drop
Integra Ida shocks
