How much travel is LR front shock?
  • kevpow
    • Feb 2012
    • 174
    Im running a MB with all Ohlin shocks. After setting the car up this past week per MB specs and frame heights, I only have about 1" of travel left in the LR front shock. Is this common or should there be more travel there?
    I wanna go Fast!!!
    • 14324
    The lr shouldn't really go below ride height very often. I would like to see 1.5" if possible. Do these shocks have remote canisters or are they the bulb type with the canister built into the end?
    • kevpow
      • Feb 2012
      • 174
      Shocks
      MB, all of my other shocks are the canister deals but the LR front is the Ohlin with bulb canister on top!. I know that when the car is on the bars, it'll be stretched out but I was worried about rebound and it bottoming out. Ive set it to ride height and scaled the car accordingly, just worried. It may be fine. I just wanted some input. Thanks for any help.
      I wanna go Fast!!!
        • 14324
        You lost travel because the bulb makes the shock body longer. How far below the axle centerline is your birdcage mount?
        • kevpow
          • Feb 2012
          • 174
          travel
          They are the bearing cages and i'd say a rough guess would be 2.5" to 3"? Im at work and the car is at the shop but by memory, it was about that much. I cant remember if there was room to drop the shock mount down?
          I wanna go Fast!!!
          • John H
            • Jun 2011
            • 24
            Make sure you have your shock mt on the birdcage at the highest location and use at least a 1" shock extension. You def. don't want to overextend the shock and damage it!
            • kevpow
              • Feb 2012
              • 174
              Travel
              John, it's not a matter of overextending, it's a matter of bottoming out! Thanks for the reply though!
              I wanna go Fast!!!
              • John H
                • Jun 2011
                • 24
                Sorry! My mistake. I zigged instead of zagged.
                • Matt49
                  • 3123
                  With the extreme travel of the shock in front of the LR, I'm surprised somebody hasn't come out with a longer stroke shock just for this application. You almost have to have an extension but then once you get the shock drop setup so that it doesn't top out before your chain catches, it does leave you with a limited amount of bump from ride height to bottomed out.
                    • 14324
                    I believe someone was making a 10 in stroke, but cant remember who.
                    • kevpow
                      • Feb 2012
                      • 174
                      Travel
                      So, I take it that this is a normal problem, or let me rephrase that...This is a common occurance. I appreciate all of your responses and i'll just keep an eye on it to make sure im not bottoming out. Mastersbilt, I may be bending your ear some more in the future. Thanks
                      I wanna go Fast!!!
                      • Sprint76
                        • Aug 2008
                        • 76
                        Saw one on one of the Bloomquist cars at Volusia this year. Can't remember who though. I think the shock was black, so it may be made by Advanced.
                        • lovinlatemodels
                          • 486
                          I believe the black shock you are refering too is Black Magic shock they do build a 10" stroke.
                          • EAMShater
                            • Aug 2008
                            • 138
                            I actually run a bump stop on my front shock so if for some reason the car ever was to come completely off the bars when slowing down getting in it wont go too far and cause the car to actually go right. I don't see a big issue with it really. I do have an 09 bwrc tho
