late model on a open trailer
  • widcard22
    • 82
    Ive seen a few latemodels on open trailers..that were 82.-84 inches wide between fenders....how wide are thease cars? What do you have to do to haul them on one of thease trailers.... if ya have pics please post.......lookin to get car and wouldnt want to buy a trailer....thks in advance.
  • supercomet32
    • Jan 2009
    • 186
    • lazermod3
      • Jan 2008
      • 1910
      we had to move our fenders 2" on each side to get the car to fit just cut the fenders off ad a peice of 2" flat stock and weld it back up. or i know guys that just take the fenders off all together.
      puts the tires real close but the cars are wide if i remember you need 82" to clear the bottom of the doors on most cars. thats why they all sit up over the fender wells on a closed hauler
      you just got greased
      http://www.goddardwarrior.net
      • supercomet32
        • Jan 2009
        • 186
        Most rules state 88" of wheel width. alot of times this might mistranslate to tire width.
        Minimum 102" wheelbase.
        • Rocky
          • 3218
          I put my chassis on an open a few days ago, no motor and it was way too wide at the front tires even with no fenders. I'm gonna have to get some narrow front tires or at least one of them. With a motor in there, I could probably winch over the tires up and on but that would be hard on the winch and I'd probably never get it back off again without taking the tires off the trailer. If it was my trailer I'd build a ramp over the wheels however it's somebody elses.
          Guerilla Racing Junkies.
          Shovel on a little more coal, then when we cross white oak mountain, watch 97 roll!
          The problem is the gall dang motors.
          • jason29a
            • 491
            Rocky... You can still build the rampover, just make them removable. Its not hard to do and really its the only way to go. You dont wont to have to fight to load the car. These cars are wide.
            • talclipse
              • 738
              If possible you definitely want to make some removable rampovers. Years ago we used front loading tires to get the car on and off a trailer. We'd have to pull the right side of the body in to haul the car. It was a pain every week having to change stuff out just to load/ unload the car (at least for us with just my dad and me there to load/ unload).
              If you cannot retrofit rampovers your only real option is to use loading tire(s) and you will more than likely need to pull the right side of the body in in order to get the car past the fenders/ trailer tires.
              • mudderfudder
                • Aug 2008
                • 264
                On my open trailer I made it so you could slide the fenders out when loading car and after we get it all strapped down we slide them back where they need to be and use hitch pins to keep them from sliding back and forth going down the road. Just make sure that the front tires are far enough ahead of the trailer tires so that you can put the fenders back in place. Hope this helps!!
                • joedoozer
                  • 745
                  Here is a link to a thread I started with my trailer. We don't need fenders in our state, so I just removed them. I was going to add some new pics with a tire rack, but can't figure out for the life of me how to upload a pic on this new forum.
                  http://www.4m.net/showthread.php?167...mpover-for-125
                  Crew Chief "Tip of the day":
                  • Rocky
                    • 3218
                    Oh I know, let's just make sure my doing this all by myself like a guy that well has no friends cause he just moved here can even get on the race track this season. the trailer can be made to work but that's my final worry. I spent a couple hours on the car tonight. Should be done with the chassis in about 2 weeks and worry about motor. Then new safety stuff then I guess I have to get it to the track...... Might be about July. Either way I'll get her there.
                    • widcard22
                      • 82
                      Thanks for all the info an links......if anyone else has ideas please post ....thanks scott
                      • RacerX10
                        • 571
                        get a loading wheel / tire and put it on the right front. they are only about $40 - $45 dollars.
                        something like this :
                        • Rocky
                          • 3218
                          That's a VW wheel, I don't think VW Wide 5 is the same as the Wide 5 on our cars least ways I know the studs would never fit through the holes in one. I wish they did though because my Dad has about 20 of those things.
                          Or does it?
                          • dirty white boy
                            • 1238
                            made my loading wheels with 2 old house trailer wheels an 10 1/2 inch long pices of 3/4 od pipe,....had to grind 5 notches for clearance,...an silicone inside of wheels at wields ,..redneck lookin kinda,..cheap an works...i had it all layin around so cost me nuttun...
                            white trash motorsports
                            • joedoozer
                              • 745
                              A loading tire wouldn't have worked in my case. The body would have hit the trailer tires. I needed to get the car up and over.
