Need advise
  • bigk44
    • Feb 2011
    • 67
    Need advise
    Came off turn 2 tonight in hot laps car started missing. Pulled valve cover and #3 intake rocker is not moving at all. Pushrod is there can't tell yet if its bent or whats up. Is it possible the lifter broke or the cam lobe broke? If cam broke the other valve train would not work, correct? #3 exhaust is very loose also. I know i will have to pull the head to see for sure. Just wondering if anyone has had this problem before?
    Thanks,
    Kevin
  • fordracer7
    • Nov 2008
    • 37
    We had that before. A cam lobe wore out. Drove us crazy trying to figure it out.
    • bigk44
      • Feb 2011
      • 67
      It was the lifter. Thankfully it only got the push rod, everything else looks ok.
      • perfconn
        • 3636
        What about the lifter? Wore out? Busted?
        • sj valley dave
          • 1016
          If it was a roller, when we have lost one, it opened up the lash by .035, but the valve obviously still went up and down...how can a lifter just kill 1/2-3/4" of valve movement??
          • bigk44
            • Feb 2011
            • 67
            It busted the lifter, and its a flat tappet. I do not have the head tore down yet to check the valve. It appears that it (the valve) has no damage. The rocker is mared up a little but looks ok.
            • perfconn
              • 3636
              You probably need a camshaft also
