I have broke the center out of two titanium retainers in the last 7 races. Retainers were new 20 races ago. Valve then drops. Any ideas what is breaking retainers?
Retainer???
What degree retainer...7*, Super 7, 10*...What brand? We only have used Crower and Del West..What is your spring rate?
Originally posted by thinker View Post150lbs spring pressure. Rev valves. 7600 rpm's. Plenty of clearance. 10 degree locks. Not sure of the brand .rockers are 1.6 crower stainless.
What are your open pressures? (more important in most cases then seat pressure) Are the locks and retainers of the valves hard to seperate? If there are no signs of float, such as locks and retainers stuck together excessively, and you have addequate open pressure. I would blame it on poor quality retainers. Check ebay for used Del west or other high end, (crower, xcyldene etc) super 7 retainers ( can be had for about $50) and machine to fit springs if needed. If your using bead groove style valves, Ti. locks can be found on Ebay cheaply aswell.Josh K.
With seat pressure of only 150 lbs, I am strongly leaning to it being a flat tappet...Never saw much of any kind of solid roller cam with only 150 of seat pressure...
