Warrior Calipers
  • joedoozer
    • 745
    Warrior Calipers
    Have a RF caliper dripping a little out of one of the pistons. Pulled it apart and the O ring feels a little "hardened". Do they sell new O rings for calipers? And what kind of info would I need to identify what caliper I have? Piston size, physical caliper body size, mounting points?
    Crew Chief "Tip of the day":
  • Sprint76
    • Aug 2008
    • 76
    You will need the piston size and brand. We change all our caliper o-rings before every season. While you have them apart, also clean up the pistons with some scotch brite or CAREFULLY with a fine wire wheel.
    Also, do not mix brands when buying o-rings. Wilwood orings won't work in an Outlaw for example.
    • joedoozer
      • 745
      Ok what brand does Warrior use? They look real similar to Willwood Forged, but I can't find anything on the caliper except Warrior.
      • zeroracing
        • 1014
        I have two of those also. They were identical to my other two outlaw ones. I rebuilt them using outlaw parts, all piston and o ring dimensions line up out of the parts boom so safe to say they are outlaw calipers.
        • rusty9cab
          • 57
          I also used outlaw o-rings when I rebuild mine. Worked great.
          • joedoozer
            • 745
            Like the ones on the bottom of this page?
            • rusty9cab
              • 57
              That's the one. The round one's will work, but I like the square one. They seem to hold up well. Make sure to lube the piston and seal good on reassembly.
              • joedoozer
                • 745
                I tried contacting dealers listed on the Outlaw site with no luck. Anyone know a dealer that sells outlaw parts? I was able to get a set of O-rings right from Outlaw, but they usually don't sell directly to customers.
                • rusty9cab
                  • 57
                  www.pitstopusa.com has them. $9.85 per pack of 4.
                  • joedoozer
                    • 745
                    Thanks. I checked there before but didn't search for "o-rings". I just used the menu on the left and looked through the brake parts. Never found anything so I moved on. I bookmarked the link to them.
