just used spring steel bracing for the first time.have seen a few cars with the braces doubled and heat shrink tubing applied anyone know what size heat shrink to use? thanks!!
Spring steel body braces
We have the higher grade (1095 Super Blue) Spring steel in 35ft rolls that can be bent in a brake and will not snap or break in a crash.
We also have the heat shrink tubing in stock in all different colors by the foot or by the 100ft roll. We also have some higher grade heat shrink with internal adhesive for extreme conditions in several colors as well.
Give us a call and we can get you the right product for your needs.Brian Ruhlman
Ruhlman Race Cars, LLC
2132 Jefferson Road
Clarklake, MI 49234
517-529-4661
www.brianruhlmanracing.com
email: brianruhlmanracing@yahoo.com
The coils that I have been getting (day motorsports) have come taped in about 8 different spots. You have to cut it open. I put zip ties around it and then cut the tape off. Then i just found it easier to cut the 40 ft coil in half and put the two straight 20ft lenths on my material rack.
We use it everywhere aside from the middle door brace on the driver's side. Thats just the way those braces were done when we picked the car up from rocket. I BELIEVE they do this because it is possible for the spring steel to break and go through the c0ckpit sheetmetal. That was always my assumption anyway.
