Getting Side Bite Out Of A Mastersbilt?
  • HuckleberryB4
    • 220
    Not sure what's gone wrong in my Smackdown, but I can't get enough sidebite out of it any more. I've done everything I can think of. Started off at 55% left have ran it down to 54%. Weight is high. Moved J bar from 8 1/2" to topped out at the frame and bottomed out at the pinion. Started off with RR shock laid inward further at the top and moved it so it's standing up more. Bars are LU-top LB-2 hole up. RU-Top, RB-Bottom with the adapter plates that shortens the bar 2". 200 LR Spring and 250 RR Spring. I'm lost. Ready to off this thing!!!!!!
  • jedclampit
    • 613
    How much travel are you getting/have available from ride height @ the rr shock?
    Does the car over steer,
    slide and tear up/heat up the rr tire,
    or drift up track all 4 wheels?
    More info will get you better help, obviously your frustrated!
    • dchamp3
      • 193
      Start checking for cracks our 09 car was the same way, tons of sidebite when we first got it and 15 races started losing it , frame started cracking the welds.
      • HuckleberryB4
        • 220
        I'll have to check my RR shock travel to give you an exact measurement, but I want to say it's around 4". I do oversteer to keep up with the rearend. I'm not tearing up any tires, but the right rear is coming in noticeably hotter than the LR and I'm getting no wear on the LR. The RF sticks, but the RR skates. Thanks Jed.
        • HuckleberryB4
          • 220
          I messed up in the first post. I started off at 54% left and am currently at 53% now.
          • jedclampit
            • 613
            Are you never able to lean on the rr while cornering or does it give up while cornering?
            You have a lot of things adjusted to the extremes toward tight, could it be too tight.... and your pinching it off to get it to turn?
            • HuckleberryB4
              • 220
              I've kind of wondered the same myself Jed. It gets on the right rear then gives up. I'm wondering if the RR is doing too much of the work and I'm not getting enough LR drive out of the car when I pick up the throttle. It's pretty good in and to the center, but just before I pick up the throttle, it wants to start skating on the RR and continues to coming off. I have started driving the car in harder and deeper this season. This could be caused by being too tight in and I'm having to rotate the car myself and breaking traction all together. Maybe I'll try to move some percentage back to the left and see what that does.
              • jedclampit
                • 613
                A lot of ways to go, depending what is going.
                Sometimes a too much rr spring will kill sidebite when the track slicks off shearing the rr tires grip.
                Some people have alot of luck with more spring in the lr than rr if they tend to set the car down on the lr on entry
                -Do you trail brake...well?
                I don't think getting your left % back up is a bad idea at all.
                What you have on it shock valving wise can have a huge affect.
                -WHat do you have?
                -What springs are across the front?
                -And bite # you run?Wheel weights?
                -Ever try lowering the r upper bar, at all?
                Jed
                • dualdj1
                  • Jun 2009
                  • 654
                  that was my thought, on first impression. sounds like could be as simple as too much RR drive angle.
                  • jedclampit
                    • 613
                    How are you limiting axle drop on the lr?
                    • HuckleberryB4
                      • 220
                      I do trail brake, but tend to set the car down on the LR because I like to run the dead bottom and don't run the big arcs getting in. RR valving is a 3.5 on comp and 5.5 on reb @ 60 psi (M2 Silvers by B&O). Springs across the front are 550 and 325. The RF is a dual stage with a 600 secondary spring on top and 700 primary on bottom. 120 lbs of bite. Wheel weights are LF 627 RF 530 LR 798 RR 686. 54% Left and 56% Rear. I have since moved some weight from left to right, so the left side percentage has been reduced from these numbers.
                      This car has a full cast motor and has to weigh a minimum of 2500 lbs. It's a limited late on 10" Hoosier tires. There's the monkey wrench. lol. Also, I have ran the top right bar as far as 1 hole up from bottom and the car seemed to feel better, but I was told to increase side bite, I needed to raise that. Thanks guys.
                      • HuckleberryB4
                        • 220
                        The LR is limited with a chain and when the car is on stands I have 12 1/4" of droop. I want to say the last time I checked with only the LR jacked up I was around 15 3/4. But I will have to double check that.
                        • jedclampit
                          • 613
                          The 10" tires are fighting you for sure. Just when your using the rr at its max to corner, you call on it for forward traction .
                          You got a bunch of stuff I'd swap off and get back to basics, especially the dual stage RF, RRL shortner, etc.
                          But , may I suggest you try :
                          putting the rr upper in the lowest hole, and taking away very close to 1% from the rear %.
                          -OR-
                          swap rear springs.
                          Wish you luck catfish!,
                          JED
                          • HuckleberryB4
                            • 220
                            I was thinking of taking the dual stage off as well. I'll reduce the rear percentage and swap springs too. Would you still suggest dropping the Right Top Bar along with these adjustments?
                            • jedclampit
                              • 613
                              ****-OR-****
                              swap rear springs.
