08 Smack not rolling over
  • orealdeal71
    • Jul 2012
    • 7
    08 Smack 604 Crate engine shocks set to 75# all four LF 500 RF 400 LR 200 LR 250 Jbar at 21 1/2 c/c 2 clicks up on pinion 8 1/2 up on frame rail top bars left and right side at 17 1/2 bottom left and right bars 15 1/2 set in nuetral position on a tacky 5/16 high bank track Can not get the car to roll over on the bars Its tight in and loose off Someone help Have changed everything or adjusted everything on the car more than once trying different things and still nothing
  • 9WRACER
    • Feb 2009
    • 585
    what are the shocks at each corner, what are the weights, left, rear and cross, where is the lead mounted? we run 3 mastersbilts with crates, PM me if you want.
    • orealdeal71
      • Jul 2012
      • 7
      [QUOTE=9WRACER;1579544]what are the shocks at each corner, what are the weights, left, rear and cross, where is the lead mounted? we run 3 mastersbilts with crates, PM me if you want.[/QUO
      No lead any where not sure what the cross is total weight is 2263 left is 663 right is 556 118 # rear bite left front shock is 2060 and right front shock is 6020 not sure what the rears are
