4 bar birdcage / indexing
  • barup
    • Jan 2012
    • 8
    Can someone answer me a couple question that i have,
    *If i mover the LLB down on the birdcage it will
    *If i move the LLB Up on the B/C it will ....
    *If i move the LUB up on the B/C it will
    *If I move the LUB down on the B/c it will
    *If i mover the RLB down on the birdcage it will
    *If i move the RLB Up on the B/C it will ....
    *If i move the RUB up on the B/C it will
    *If I move the RUB down on the B/c it will
    thank you
  • Dirt Knife
    • Jun 2012
    • 147
    Network Solutions - Original domain name registration and reservation services with variety of internet-related business offerings. Quick, dependable and reliable.
      lub down on cage: Increase cage counter-clockwise rotation for a given amount of droop (drop) travel. This results in a softer spring rate and a greater bar angle. It also increases the amount of thrust force in the bar during initial acceleration off the corner and increased loose roll steer. How these changes effect your car can only be determined by the settings you currently have. Too much of a good thing, (index, bar angle, etc) can have opposite effects of what you expect.
