Bert
  • dfhotlm33c
    • Apr 2011
    • 224
    Bert
    AS I've said in previous posts, we are looking to really upgrade after two years of getting our feet wet and getting the hang of driving a late model. Don't laugh now, but we have been running a Saginaw three speed with a triple disc clutch behind our 550hp 377. I know switching to a Bert yields immediate gains in weight distribution advantages. Beyond that, what are we losing by NOT running one? I am looking for the best places to spend money and yield the greatest improvement. Is there truly a significant difference in acceleration, etc when running a ballspline Bert? Anyone ever make this switch that can attest to true differences?
    • 14319
    Losing the clutch and going with a Bert or Brinn will make a huge difference in engine response. It doesn't have to be a ballspline. In fact, I wouldn't use one of those without a carbon fiber driveshaft.
    • dfhotlm33c
      • Apr 2011
      • 224
      Interesting. May I ask why? The car came with a driveshaft for what the old owner said was a bert ballspline. So, if I go with "normal" Bert, is the u-joint the same? Length? Thanks for the input!
      • PA Dirt Fan
        • Jul 2012
        • 24
        Less rotating weight inside the transmission,lighter case and true direct drive when in high gear also very light weight flywheel and the ability to run oil system off the fly wheel if your in a late model and don't have a Bert or brinn your back in the stone ages and the new Bert's are even lighter inside and out
        The reason for the carbon fiber shaft with a ball spline is for the possibility of the ball spline assembly jamming and with a steel or aluminum shaft it gets extremely violent the carbon fiber will shatter to keep damage to a minimum We broke a small steel shaft with a regular Bert due to a joint failure it was crazy how much damage occurred took the x brace out lift bar broke and went in to the seat leg braces we will never run anything other than carbon fiber shafts now
        • restad4r
          • Jun 2011
          • 79
          I agree 100%. If you use a ball spline your crazy if you dont use a carbon fiber drive shaft. The damage you will do to your chassis and parts is way more expensive then a drive shaft, not to mention it's extremely dangerous to the driver.
          My 2 cents
          Ant
          • C10
            • Nov 2008
            • 359
            Yup, but it sucks IMCA doesnt allow the CF shaft
            • lovinlatemodels
              • 486
              Wow i have run steel drive shafts from Wiles for 12 yrs with my ball spline with no problems. Sounds like lack of maintence. I've broke one drive shaft in 23 yrs only due to a j bar heim broke and allow the rear to move cutting the drive shaft on a bolt.
              • talclipse
                • 738
                To the original poster you'll see some significant gains due to the reduced rotating weight a bert provides as well as a significant reduction in overall weight by the time you eliminate the scatter shield and all of the hardware associate with your factory transmission. If you are on a tight budget go with a first generation non-ball spline transmission. Make sure the input shaft has splines all the way up it and bi-weekly remove the drive shaft and grease your splines to help ease the friction there. If you have the budget for a ball spline add $750 to the cost of it in order to get a carbon fiber drive shaft.
                A carbon fiber drive shaft should be mandatory for anyone running a ball spline. Its one of those things you may get by with for 12 years or your entire career and never have a parts failure resulting in the drive shaft breaking; but, all it takes is just once for that thing to jump in the CP with you and you have the potential to bleed out before the ambulance even gets to you.
                  There's no amount of money you could pay me to race a car with a ball spline transmission without a carbon fiber drive shaft.
                  • dfhotlm33c
                    • Apr 2011
                    • 224
                    Thanks so much for the responses! This is certainly helping me to make a decision. So, the driveshaft we currently have for our Saginaw, will the yoke be the same if we get a standard Bert (Non-ballspline)? How about the length? We currently have about three inches of travel on our yoke now, so will that work out? Thanks again! (And just to be clear, it is true that I need the Bert bellhousing and reverse mount starter, right?)
                    • JustAddDirt
                      • 1893
                      transmission
                      To keep the same length driveshaft you would need a Brinn Transmission. They are the same length as the saginaw.
                      As for the bellhouing, I would recommend a bert or brinn reverse mount bellhousing, but you can run what you have now with an automoatic flexplate and block mount starter. it will work, just have to watch bellhousing cracking (if it is aluminum)
                        • 14319
                        The driveshaft is to save you IN CASE you have a failure. I have only lost one ever. It was when a lift bar failed. I still wouldn't run a ballspine without the CF shaft.
                        • RACR_73s
                          • 879
                          I believe that the Falcon is also the same as a Saginaw. I have a Falcon and have not had any trouble with mine in 4 yrs. I think you can generally pick up a used Falcon cheaper than a Brinn. I have seen many Falcons in the $500-600 range and actually paid $550 for one.
                          • dualdj1
                            • Jun 2009
                            • 654
                            there are risks in all parts of racing. it's up to you where you want to take those risks. many people run alum driveshafts with ballsplines with no prob. even without a ballspline, there's still a risk breaking something and getting a driveshaft into the (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit. if you have the budget, cf is obviously the way to go, because there are other benefits such as weight. but obviously from people's experience, the risk without a CF one is still very low. so, in the end, it's just how much risk you're willing to take, same as everything else.
                            • 7uptruckracer
                              I've only had one break as well the actual yoke broke inside the trans and not the shaft itself and let me tell you it only takes one time and I have the scars to prove it. It cut a 4 by 6 gash to the bone on my femur and barely missed the artery, the hot fluids burnt my leg up and suffered a MRSA infection over 9k in doctors bills isn't worth it and from the muscle that got cut out and the tissues it messed up I regret not having CF. I'm only 27 years old and some morning feels like that leg is 80 so go with CF even if it takes you longer to get the car on the track its worth saving up the money.
