heads
  • 95rayburn
    • Sep 2012
    • 162
    heads
    What's the pro's and con's of 15 degree brodix heads compaired to 23 degree head's
  • perfconn
    • 3636
    Will make a ton more power.Must change pistons,intake,headers and rockers,probably need to change cam.
    • sj valley dave
      • 1016
      It's why Cup cars got away from 23* heads in the early 80's, went to 18* stuff, then canted valve 11*/8* SB2.2 and now the R07 with 14*/10* angles...shallower valve angles have a smaller chamber and make tons more power...no comparison
      • 4bangerhotrod
        • 374
        i dont know anyone that has run the brodix 15* head, does anyone know what kind of hp an torque numbers these heads are capable of. and what kind of torque curve are they pretty smooth heads.
        • perfconn
          • 3636
          Lots of late models run them.HP and torque capabilities depends on how big the engine is,how good the heads and intake are ported and how good your engine builder is.
          • go2fast
            • Jan 2009
            • 358
            you are looking about 775 hp and 620 tq with a 404 ci engine
            • 95rayburn
              • Sep 2012
              • 162
              Why would u have to change can? Currently in have a 650 lift solid roller cam
              • perfconn
                • 3636
                Because the 15* heads will flow so much better than the 23* heads.You may need new lifters also that have offset intakes if you don't already have them.
                • go2fast
                  • Jan 2009
                  • 358
                  with the 15 deg heads you go to about a .780 lift on the in and .750 lift on ex 1.75 in rocker and a 1.7 rocker on the ex cam with a .442 lobs
                  • perfconn
                    • 3636
                    Those are not the important numbers on having the right camshaft.I can use those numbers and you will have an engine that won't be anything but a pig off the corners or use those same numbers and it will blow the tires off.There is more to to the right cam than lift.
                    • go2fast
                      • Jan 2009
                      • 358
                      Well the cam we used is 260 in and 268 ex on a 55mm core and a 107 center line put in @ 103 with .903 lifters will make it about a 261/269 peek tork 5500 rpm peek hp about 7400 rpm trun it about 8300
