oil cooler
  • 37mod
    • 88
    oil cooler
    Is it posible to use an oil cooler made in the radiator ok to use with a dry sump system?
  • perfconn
    • 3636
    Yes but it doesn't work as efficiently as a seperate oil to air cooler.Also if you ever get a hole in the seperator plate you will get oil and water mixing.
    • 37mod
      • 88
      So does a deck mount cooler do enough cooling? Will the radiator mounted cooler create to much back pressure?
      • perfconn
        • 3636
        850hp supers use a deck mounted cooler so yes they will work.Cooler inside radiator will not create back pressure,just doesn't cool as well.You have to keep in mind that 200-210* water will not cool as well as 70-80* air.
        • FlatTire
          • 560
          I've used both types of coolers, and my deck mounted air to oil cooler cools 5-10degrees better than my water to oil cooler built into the radiator did.
          Also makes your radiators cheaper and easier to get.
