What length springs are you guys running on your set up? I figured 4" and 8" but heard the short spring, 4", may coil bind. Was thinking of using a 6" and 7". Any thoughts out there? I'm sure this has been covered and if so I apologize. John 1*
double spring right front?
— HeraclitusTags: None
You can use a 5" and 8". A 7" and 6" is common. If you have a 6" on the bottom, you need a spacer between them with the long part of the nylon sleeve pointing up to avoid the spring catching on the end of the shock body.Modern Day Spec Wedge Racing
Thank you very much kind sir. I haven't ran anything quite like this yet and I think I understand what I want to do but seems there may be a better combo than others. Just wanted to take as much out of the learning curve as posible. Thanks again John 1*Originally posted by MasterSbilt_Racer View PostYou can use a 5" and 8". A 7" and 6" is common. If you have a 6" on the bottom, you need a spacer between them with the long part of the nylon sleeve pointing up to avoid the spring catching on the end of the shock body.Last edited by jrkracing54; 12-16-2012, 04:40 PM."Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back."
— Heraclitus
