Winterizing Aluminum Engine
  • rocketmanstan09
    • 7
    Just wondered what you all do when winterizing your aluminum engines. Our shop isn't heated. Just wondered if you all put antifreeze in them and what kind that won't hurt the aluminum. Or is it best to find a heated place to store the engine? Thanks
  • HEAVY DUTY
    • 796
    Pull the block plugs, and drain all the water. You shouldnt need to put anything in it. Also run it with gas and oil mixture until it smokes to lubricate the cylinder walls, before you drain it.
    • catgo22
      • 317
      I undo the radiator hoses and use an electric leaf blower in the top hose to blow the water out of the block. Takes about 2-3 minutes to get to where nothing is coming out. Then blow the radiator out through the radiator cap. Never have had a problem. www.riekertracing.blogspot.com
      • SLM98
        • 407
        Take all the rockers off the engine to take pressure off the springs. This will also seat the valves to keep the valve seats from rusting. I go and squirt oil in the cylinders and rotate over once a month to help keep cylinders from rusting.
        • MQueen
          • Jan 2011
          • 43
          This has never let me down 20+ yrs. Fire up the engine, bring it up to 2k rpm and pour 1/2 a quart of ATF through the carb in about 5 seconds. Let off the throttle and she will quit, this lubes the entire top end. Pull the carb, drain the fuel and pour the remaining atf in each bowl through the vent tube, pump it till you get oil out the squirters and bolt it back on. Back off the rockers to seal the cylinders. Drian the block and radiator and thats it. Next year adjust the valves pour in your water and she will fire right up. Dont even have to drain the oil out of carb this will mix with the gas and give you a nice lubed up restart. If you run Alcohol trade out the ATF for Klotz 2 cycle oil.
          • let-r-eat
            • 2319
            MQueen,Does the M stand for Mark?
            BUCKLE UP NOW, YA HEAR?
            • MQueen
              • Jan 2011
              • 43
              Yep, that would be me.
              • MQueen
                • Jan 2011
                • 43
                Could this possibly be one of the Stanakers I met in Elkins many years ago?
                • DANNY
                  • 791
                  I do something close but with Marvel Mystery Oil. Put it in carb and till it squirts then pour some in down there too pull the plugs crank it over little bit till it starts shooting out the plug holes put plugs back in finger tite. Comes time to fire up I pump the carb fairly dry then pull the plugs again turn her over till it again starts shooting oil out the holes this then should have brought oil and fuel press up with no real strain on stuff as its turning over freely. Pop the plugs back in and proceed to fire it up... (Of course drain/refill water as well)
                  »»*†HÀ†§ HÓ††™««
