Im running a rayburn swing arm all the rayburn's ive looked at have the jbar/panhard bar mounted to the right side frame where mines mounted from the left side frame to right side of pinion. Would that have a different effect compared to the typical right side frame mount and if I raised and lowered my jbar on the frame side what affect would it have on the car besides moving the rear end left or right thanks for any advise
j bar
Moving just the frame end or lowering just the pinion end increases the rake in the j-bar, which increases RR bite and the speed of the reaction to the RR. Raising the J-bar at both ends equally will loosen the car and conversely lowering both ends equally will tighten the car. Be careful, you can get to radical with excessive rake in the j-bar and the car will get erratic. On the slicker tracks it pays to try and drive straighter and lower both trailing arms down to get the rear of the car to steer itself during body roll. I watched Jonathan Davenport a few years back blister a full field of 4 link cars with his Rayburn on a very slick/flat track with the setup your running. Good luck in 2013.Originally posted by 95rayburn View PostIm running a rayburn swing arm all the rayburn's ive looked at have the jbar/panhard bar mounted to the right side frame where mines mounted from the left side frame to right side of pinion. Would that have a different effect compared to the typical right side frame mount and if I raised and lowered my jbar on the frame side what affect would it have on the car besides moving the rear end left or right thanks for any advise"If racing were easy, everybody would do it."
#77 Leon "Slick" Sells
I had a friend who was working with CJ and Frank McClendon(Custom Chassis) modifying an existing Rayburn to be Reverse Canti-lever and they did something along those lines with a 25" J-bar. But I've never tried reversing the purple bar to the LS frame, but I'd assume it'd be about the same as a long j-bar.Originally posted by old17ford View PostHas any body ever tried the long purple bar from the left frame to the wart hog on the right axle tube ?"If racing were easy, everybody would do it."
it could be done, but would seem to me that you'd lose the advantages of the j-bar, mainly leverage. your dynamic wedge wouldn't change as much either, which could be good/bad depending on what you're trying to accomplish.Originally posted by old17ford View PostHas any body ever tried the long purple bar from the left frame to the wart hog on the right axle tube ?
