Pro's & cons on rr brake
  • twisterf5
    • May 2012
    • 334
    what are your thoughts on the right rear brake being on the bird cage instead of clamped to the tube.what would it do to the handling of the car.
  • rich tanner
    • Nov 2010
    • 18
    Birdcage mounted calipers.All brake torque is fed thru the trailing arms.This arrangement usually provides anti-dive and tends to load the rear tires when the brakes are used.This requires smooth braking and can tighten decel handling when used correctly on RR.It will loosen decel handling when used on LR.
