I have a parasitic draw on the battery. The only fuse that makes a difference when pulled is number 29 under the hood listed as Radio Bat (10 amp). When I pull that fuse the draw is gone, car will start but radio heater and a bunch of other things won't work without it. I pulled the dash unhooked the STOCK radio no wires cut or bare that I can see. I unhooked the heater controls and what not but draw is still there. Hell I even unhooked the alternator just in case. Any ideas??
s?
disconnect the positive batt cable,use a test light,hook it to the positive post and then touch the cable there should be a glow,disconnect electonics until the light goes dim or out,youll see a big difference in the light but it still may have just a little draw with todays cars so the light may not go out completely,it will take a friends help but works everytime
