2002 GRT wide front I checked the ackermann in my front end and the RF is out steering the LF BY 5/8" how do I correct this or should i worry with it? I was reading about this in Bob Bolles book and checked it out on my car.
Ackermann ?
Sounds like your spindles are mismatched. You need to buy the correct ones. The steering arm should be shorter on the lf spindle.Modern Day Spec Wedge Racing
Slide the rack back if you have slotted mounts. The more angle forward from the rack to the steering arms, the more ackerman you will have.You definitely dont want it toeing in as you turn.
They should be the same or shorter lf for any car I know of. He was off so far I figured that was his problem. Spindles for the same car, but from different suppliers often have different steering arm lengths.Originally posted by 95rayburn View PostWould it be the same on a rayburn where the lf would have a shorter steering arm than the RF?Modern Day Spec Wedge Racing
I think thats one problem the spindles I have are not from GRT and the steering arm lengths are not what joe said they should be, I bought this car and the guy told me he wanted the rack off of it and he would put the one off his other car on it. He said it had a very fast ratio that he wanted, so I agreed to it. I think by doing this I have ended up with the wrong length rack. I need a 19 3/4.
I understand that about the inner control arm pivot and inner tie rod pivot but I dont understand how the upper control arm pivots could be in the same line, the way I am seeing this is paralell to the frame rail, to me the upper control arm pivots are outside these points, right? Help me to understand what your seeing here.Originally posted by let-r-eat View PostYes. You should be able to draw a straight line through your lower control arm pivot, inner tie rod pivot and upper control arm pivot.
I was wondering about that too. Its the lower/inner pivots you should be concerned with, the top control arm pivot has no bearing on it. I think he mistyped.Originally posted by mignum View PostI understand that about the inner control arm pivot and inner tie rod pivot but I dont understand how the upper control arm pivots could be in the same line, the way I am seeing this is paralell to the frame rail, to me the upper control arm pivots are outside these points, right? Help me to understand what your seeing here."If racing were easy, everybody would do it."
#77 Leon "Slick" Sells
I did not mess with it alot but it looked like to me if I line up the inner pivot points that the rack end on the left side is sticking out so far that it doesnt leave much room to turn left. But I will start on it in the morning and see how far I can get, thanks to everyone for your much needed input.
I worked on the car today and I measured and my rack is 19 1/4 and the inner pivots are 19. checked all my measurements multiple times and I still come up with 5/8 toe in, I dont know what to do too fix the reverse ackermann problem, can I just shorten my left steering arm?Last edited by mignum; 02-02-2013, 06:51 PM.
I wouldnt just shorten the steering arm. I would get the right spindles and rack for it so everything will be right. If the rest of the spindle ( height, drop, inclination) isnt right, the whole front end will be screwed up. I am a chassis builder and see people buy used stuff to save money and it ends up costing them more to make it right in the end, and they make the chassis builder look bad when the car doesnt work right when all the parts are wrong.There is a lot to the design of a front end and it all has to work together.It costs alot to buy new parts, but it costs way more to drag a car that dont turn to the racetrack week in and week out and never win any money. I dont want to sound like a jerk, but I am trying to save you a lot of hassle.Originally posted by mignum View PostI worked on the car today and I measured and my rack is 19 1/4 and the inner pivots are 19. checked all my measurements multiple times and I still come up with 5/8 toe in, I dont know what to do too fix the reverse ackermann problem, can I just shorten my left steering arm?
