my new rocket has grey spindels and instead of having the serated ends on them they have bolt on like the older styler what is the benifits of having the serated ends? also mine have 2 bolt holes the lf is bolted in the black hole and the rf is bolted in the front hole? is there a reason why?
grey rocket spindels
You need to remember that having the left side in the short hole and the right in the long hole increases toe-out when turning in and then goes radically to toe-in when counter steering. (check it with your toe plates) If you're a "drive it straight" driver your set-up is probably OK. If you have to counter steer it's gonna push in the middle of the turn.
