lay down shock
  • 95rayburn
    • Sep 2012
    • 162
    lay down shock
    What is a lay down shock and what's its purpose how does it work
    Do you mean "hold down" shock?
    Soft compression, stiff rebound in RF. Idea is to pin the RF down so that the LR is up. Reasons why you may want to do this are a many.
    • JJ128
      • Jul 2011
      • 92
      Lay down shock
      A shock that goes from the top of the quick change to a bar in front of the fuel cell is sometimes called a lay-down shock. If that is what you are talking about, I think the primary reason to run one is to tighten the car on entry. Similar to a 90/10 shock running toward the front of the car, or adding more rebound to the 5th coil shock. That's a general statement of course, I'm sure somebody else can add more to it.
      • MQueen
        • Jan 2011
        • 43
        This is what happens when you write the check for your new shocks. You have to lay down because of shock. (Lay down shock)
        • dualdj1
          • Jun 2009
          • 654
          yep that should be it. rayburn uses 2 90/10 shocks because of the pull bar, keeps it from kicking back forward too quick after letting off throttle.
            I think that there was another recent thread about this very topic that had a lot of information about this.
            • drtrkr244
              • 1024
              Thats funny right there, but TRUE!
              I thought everyone had $4800 laying around for a set of JRI's latest and greatest.
              • dualdj1
                • Jun 2009
                • 654
                Thanks Matt. Haven't been on as much lately, so sure i've missed a few threads
