I have a 2002 black frontend rocket. Looking to upgrade to bearing birdcages. Which ones should i go with. Bsb, Or twm,or rocket? Or any other ones to consider? Thanks
birdcages
Give chad @ wehrs machine a call, great quality products! Check out the website. Www.wehrsmachine.com
Is there a measurement to locate bird cages on axle tube with a rocket chassis? I put new bird cages on new tubes so I want to get them in the right place.
Not sure of measurement but if you have brake floaters on either one you can mount up a hub and rotor and use the caliper to guide you.Originally posted by ncracer1st View PostIs there a measurement to locate bird cages on axle tube with a rocket chassis? I put new bird cages on new tubes so I want to get them in the right place.
There is no mesurement. If you have the proper birdcages and rearend tubes, the birdcage butts up to the brake caliper bracket.Originally posted by ncracer1st View PostIs there a measurement to locate bird cages on axle tube with a rocket chassis? I put new bird cages on new tubes so I want to get them in the right place.
Spacers may be required. If they were purchased new, they should come with them. You just have to know where to put them. Obvious to some people but not so much to others. So I can understand why some may want an additional reference point to get it right.Originally posted by drtrkr244 View PostThere is no mesurement. If you have the proper birdcages and rearend tubes, the birdcage butts up to the brake caliper bracket.
We bought a new rearend and birdcages from Rocket last year. We were told not to use any spacers only the reatainers on the inside.Originally posted by Matt49 View PostSpacers may be required. If they were purchased new, they should come with them. You just have to know where to put them. Obvious to some people but not so much to others. So I can understand why some may want an additional reference point to get it right.
Maybe, the older cars used wider tubes or different birdcages.
I'd call Anthony in parts and get the correct placement....easy enough....so you don't end up with a queer car and extra holes in the tubes if you find out they are on wrong later.Originally posted by ncracer1st View PostIs there a measurement to locate bird cages on axle tube with a rocket chassis? I put new bird cages on new tubes so I want to get them in the right place.
