Hossier tire 1600 differences
  • LateModel B23
    • Oct 2012
    • 283
    What is the difference between the 29.0/11.0/15 NRM1600 and the 11.0/29.0/15 NRM1600??
    I notice they have different part/stock numbers, but I am not seeing any differences in the description at the online catalog details. Links below:
  • pajamie
    • 310
    one is what they call a "white dot" I think its the 11.0/29.0/15 NRM Correct me guys if I have it backwards..
    They say the white dots seem to take heat alot better and wont seal over as fast..
    • dfhotlm33c
      • Apr 2011
      • 224
      Not to hijack, but what does the NRM designation refer to?
      • stittracer99
        • 27
        yes pajamie, you are right. the 11.0/29.0-15 is the white dot and it is supposed to fire faster. also, the NRM stands for "new rib mold". Hoosier recommends using these tires for most side bite getting in and on tight corner tracks.
        • dfhotlm33c
          • Apr 2011
          • 224
          Thanks...so given a choice between NRM and C4000 construction tires on a small 1/3 mile flat corner track, which would be a better choice?
          • LateModel B23
            • Oct 2012
            • 283
            So given this tire rule for weekly racing on 1/2 mile with sweeping corners and a promise that it will be slick due to 305 sprint cars on weekly schedule, what would you use given this tire rule:
            WRS or WRS2 - Any 55 - Any 1600
              • 2020
              Bill, the 1600's or a 40 if allowed. Just keep in mind sidewalls on the RR can change the car switching from a 1600/40 to a wrs in handling.
              • LateModel B23
                • Oct 2012
                • 283
                Thanks, I have some old WRS2's but when I say old, well they are old. I need a set of new so just trying to find out which is the best way to go.
