Bert starter/flywheel grind issue
  • merc123
    • 1261
    First time running a Bert. I got it all bolted up with a new starter. I've spun the motor over with it several times and even used it to get the oil pressure up in the motor where it had been sitting. It would spin for a good 30 or 45 seconds with no problems.
    Recently we tightened down the front motor mount bolts to the chassis, put the driveshaft in, added brake fluid to the tranny and bled it, then filled with ATF fluid. I turned the motor over to show my crew chief how fast the motor spun over with the Bert vs. the stock starter and then went inside.
    Tonight I went to turn it over to check a power steering leak and it would turn and then start grinding and stop turning. When I looked at it the gear in the bell housing engages (fully) the flywheel then it slips back to it's "start" position. I added grease to it through the fitting and checked it again and it's still doing it. What might be the problem?
    Web: http://www.t17.co
  • Rhino22r
    • Mar 2010
    • 36
    You probably need to add spacers on the back of your crank. There's a clearance spec, don't remember it now, but it isn't much. Add the midplate and you have a huge gap there. One of the suppliers sells a kit for it.
    • merc123
      • 1261
      I don't think it's the flywheel. I think it's either the starter or the idler gear. The gear is completely engaged on the flywheel and then it starts to move back to the original position which causes it to slip off the flywheel and grind. I'm wondering if it's the starter not working right to push the idler gear out.
      • AmickRacing
        • 236
        throwing some ideas out there... throw the battery charger on it for a while and try. Maybe the battery is getting a little low and not allowing the starter to push the gear out far enough?
        Home Page
        http://www.AmickRacing.com
        • Matt49
          • 3123
          If it appears to be engaging all the way and then backing off it could be a starter problem. But check your gap to be sure. Should be 60-80 thousandths when not engaged.
          I've always been told to and always have used an oil primer prior to the first start of the season rather than using the starter. Off topic but something to take into consideration.
          • merc123
            • 1261
            I will try that. It is pushing the gear far enough. It's just backing off after a half to 3/4 turn of motor.
            I will check gap. Going to pull starter tomorrow and check it too. I read that about priming after the fact also.
            • 9WRACER
              • Feb 2009
              • 585
              Is this a bert or a brinn bellhousing? We found that a brinn bellhousing takes a brinn flywheel. The bert is just a little bit smaller in diameter and it will work for awhile, then it knocks the teeth off the flywheel and won't stay engaged. Fought this forever til I got a brinn flywheel and compaired the difference.
              • JustAddDirt
                • 1893
                starter
                What brand of starter do you have?
                Might be a problem in the bendix assembly.
                All race starters (such as Bert, and others) start life starting Toyota 4 cylinder trucks.
                But they need a spring removed in the bendix assembly to work as a race starter.
                They also need the gear welded on so it does not push back the splines on the shaft, and it engages the idler gear. Very simple. Been building my own for years.
                • merc123
                  • 1261
                  Bert bell. Bert flywheel. It's a 2 piece flywheel. I'm wondering if I have the ring on backwards?
                  Charged battery. It's was at 60%, now at 100%.
                  I have used a new Powermaster XS starter. Going over to a friend's to get his starter and see what it does.
                  Checked and it is not in any gear.
                  • merc123
                    • 1261
                    Tried my starter on friends motor and works just fine.
                    Tried another battery just in case mine had a bad cell, no dice.
                    Measured the spacing and used some feeler gauges and added up they were about .122. Guess I'll have to get a crank spacer...
                    • JustAddDirt
                      • 1893
                      crank gear
                      Make sure you have the gear on the correct direction, I am not even sure if it would go on backwards.
                      Almost certain you need a couple spacters to shim the gear back and you will b good to go.
                      • merc123
                        • 1261
                        I turned the ring around and it is indeed on right. Turning it around definitely won't allow for complete engagement. With the gear completely pushed as far as it would go it would only engage 1/4 of the teeth.
                        Something else I did was I held a screw driver against the back of the idler gear to the point where the starter pushed it out. As long as I held the screw driver and the idler gear out it would keep spinning. Once I removed the screw driver the idler gear would disengage the flywheel and move back to the start position while still spinning then kick back out and grinds against the flywheel.
                        • LH17
                          • Oct 2009
                          • 28
                          put a flate washer between the starter and the bellhousing put bolts thru the starter then put one flate washer on bolt some time it takes two to fix the problem try it problem will be gone
                          • merc123
                            • 1261
                            Space the starter away from the bell housing?
                            • JustAddDirt
                              • 1893
                              starter
                              is your starter a race starter?
                              just wandering if someone forgot to remove one of the springs insde the starter bendix.
                              the gear should flip easily in and out, with no resistance.
