Is that measured from ride height, then measured again jacking the left rear ?
That is measuring between the reference points used for ride height, except doing it with the lr fully extended. Jack the chassis under the seat and measure between frame and axle tube.
Actually the car should be sitting on jack stands with the rear hanging on both sides. It should be between 12 3/4 - 13 1/4. Driver preference and track conditions will determine the setting that you need only trial and error will give you the true answers you need.
Correct. People use different methods to measure as well. If you let both sides drop, the measurement needs to be closer to 12.5. If you keep the rt side near ride height, then you are looking at more like 13.5 Jacking the car should be more repeatable for people with different types of shocks.
