lr springs
  • lpd1
    • Mar 2011
    • 104
    lr springs
    how do you get a 183lb lr spring? is that a stack spring or what they call a double stack with a adjustment nut in the middle? what spring would be better in the slick a 200 lb spring or a 133 stack spring or a 183 lb spring
    325 and 425 stacked would be 184.
    You could also have a custom spring manufactured.
    The best spring is the one that best matches the rest of your setup, your track, and your driver. A softer spring can make the lr corner come up higher. A softer spring could also fail to give the lr tire enough bite to even climb the bars.
    Your setup is a million different variables that all come together to make the car drive the way it is. You can make a car run the same lap times with a 400 lr, a stack of two 400 springs, or a 250 spring.
    • Ruhlman Race Cars
      • Oct 2007
      • 285
      Hyperco 14-185 is the part number for a 14" 185# spring.
      We have them in stock at $59.99 each.
      Brian Ruhlman
      Ruhlman Race Cars, LLC
      2132 Jefferson Road
      Clarklake, MI 49234
      517-529-4661
      www.brianruhlmanracing.com
      email: brianruhlmanracing@yahoo.com
      • rayburn62
        • May 2008
        • 25
        Are people actually running that spring in the left rear? I thought the fad of super light springs in the left rear was gone. Does it work with a 225+ pound driver?
          On a lot of cars, it is rarely being used. You could probably do ok with a block of wood.
          • grt74
            • Jul 2009
            • 1380
            Im not going to give it all out but think about it,it will only take a minute,yes some people run soft lr springs but why and also if its that soft of a spring what about when you dump the gas or let off really quick,it comes crashing down so youll have to think about that also,just saying
            • lovinlatemodels
              • 486
              Never had any luck with the soft stuff. 225 was as low as I could go been as high as 275.
