Chassis design?
  • Pete
    • Nov 2010
    • 55
    Chassis design?
    Anyone know much lead or trail is built in the rear suspension mounts by chassis builders (Mastersbilt, Rocket, Barry Wright an etc.)?
  • ALF401
    • 164
    I asked about how to square a rear end and got a ton of different ideas! apparently dlm are all over the board on this! From 1/2" to over an 1" on some cars. Let's hear from you guys how much your car has and how you determine the trail setting on the right rear.
    As a side note, I have found that car builders will tell you it's square by just setting the rods to the required lengths. It turns out that they aren't really square! it's just where they want you to start.
    • grt74
      • Jul 2009
      • 1380
      there all a little different,but if you call them they should be able to tell you where to start from,they all have a spot that is straight (or what guys will call square)to measure from
      plum bob is your best friend on this and a tape is his cousin
      • let-r-eat
        • 2319
        Square the rear end to what? I think those positions will be more focused upon the bar lengths desired and then position the mounting points.If I were building a chassis I would look at the direction the contact patches were traveling and after bar lengths were determined, then position the mounting points. Short bars that react quicker? Long bars that react slower but with more leverage available? Lots of variables involved.
        BUCKLE UP NOW, YA HEAR?
        • SLM98
          • 407
          Like the rear square
          My mastersbilts have been trailed about 5/8". The last one I got I had them build it with the LR mounts back that amount and with the rear square with the front the bar lenths are the same
          • lovinlatemodels
            • 486
            Swartz chassis have a place on the 4 bar mount to measure from to square up the rear How much trail built in is I think a 1/2 inch but all builders are different.
