Got a new aluminum motor put in my car,keep in mind the only thing i changed from previous motor was had to get a new ditributor due to tall deck,now heres whats goin on fired motor up runs fine good oil pressure until about 8 to 10 minutes of running then oil prs starts going down and bouncing back up and eventually loses it,not sure what to think any suggestions please.ps i run a 4 stage dry sump system.
Need feedback with motor issue
sounds like the pressure regulator in pump is stuck openOriginally posted by Rocket 1 View PostGot a new aluminum motor put in my car,keep in mind the only thing i changed from previous motor was had to get a new ditributor due to tall deck,now heres whats goin on fired motor up runs fine good oil pressure until about 8 to 10 minutes of running then oil prs starts going down and bouncing back up and eventually loses it,not sure what to think any suggestions please.ps i run a 4 stage dry sump system.
I agree with twister also had a bad oil filter do the same thing once the da m thing would suck in and squeeze off the oil flow you could shut the motor off wait 5 min refire to good pressure and then it would start bouncing around again. once I changed it we had no more trouble.
