Measuring lower control arm
  • merc123
    • 1261
    I've gotten 100 different answers. It is on a GRT and the LF is a 16 5/8" one piece lower.
    I have a 2-piece lower control arm that measures the following:
    Center of ball joint to center of heim: 18 1/2"
    Center of ball joint to end of tube (not including heim or jam nut): 17"
    End of tube to end of ball joint ring: 18"
    The only sizes I've seen are 18", 18 5/8" and 19". 18" I know is too short.
    Web: http://www.t17.co
    You have a 18 and 5/8 with the heim run in a tad too far.
    • merc123
      • 1261
      So what would happen if I just go ahead and buy the 19" giving me the "wide front end" GRT? Increase negative camber on the RF?
      • 7uptruckracer
        Are you on their Updated Spindles? I always hated how tight those cars were....
        • merc123
          • 1261
          Not on the updated spindles. We actually had to tighten the car up because it was too loose.
          The left side is the standard GRT 16 5/8" though. I think the wides had a smaller left, like 15 5/8" though.
          • sj valley dave
            • 1016
            We have the std 16 5/8" on the LF and went to the 19" RF with a 7 3/4" upper a arm. The driver likes it way better than the std 17 5/8" deal..The car will turn where ever and whenever he wants now..We can put more neg camber in and it gains it quicker..
            • merc123
              • 1261
              Top is a little longer. Looks about a 8 1/2 but I measured left at 10 1/2 and it has 10 etched in the back of it
              • Driver 44
                • 41
                Travis, if you want to update to the wide front end i have two complete sets i'll sell reasonable. 2left spindles,2 right spindles,2 one piece lowers for ea side and 2 uppers for ea side.Call me if you still have my # from when you were hunting the yoke.
                • mignum
                  • Sep 2010
                  • 140
                  I have a original wide front car and I think that the inner mounting points are in a different place than the old fronts so dont think that you can just put on the wide front, it may work but not sure how the geometry will be.
                  • merc123
                    • 1261
                    It isn't a 18 5/8". I bought one from Southwest Speed and got it put on and had -8* of camber. Replaced the spindle and upper (bent) and still had to put about 3/4" worth of washers to get it down to a reasonable camber amount.
                    The problem I'm seeing is differences in lower control arms. We tested a AFCO 18" up against it and it was way to short. We would have to lengthen the heim out way to far. The 18 5/8" is too long by a lot even with it all the way in.
                    I did call the company that made the one I have and by measurements, they consider it a 19".
                    • mignum
                      • Sep 2010
                      • 140
                      I use 1" spacers at the moment for the upper on my wide front.
