Falcon vs. Brinn
  • LateModel B23
    • Oct 2012
    • 283
    Falcon vs. Brinn
    I have used Brinn transmissions since they first came out. Had one that got damaged due to driveshaft coming out. Is or can a Falcon replace it directly? In other words can the Brinn be un-bolted and Falcon bolt right back in using the Brinn bellhousing and flywheel with the pump(s) mounted on it? Is overall length the same so the same length driveshaft will be used?
    I understand if there are shifter linkage adjustments/changes, that is not my concern. I need to get the car fixed and can get a deal on a Falcon that would let me save some $$$$ over a new Brinn at this time.
  • zeroracing
    • 1014
    I have the falcon, and been told it is the same dimensionally, but never had a brinn. I use the winters assembly.
    My question is though what about fixing the brinn? You can get new tails, cases, anything for them and that might save you the most coin.
    • sidebite7
      • Feb 2013
      • 32
      yes it is a direct replacement. I switched to a falcon from a brinn . the falcon is the same length as a brinn, therefore the driveshaft is the same. you are correct, the falcon shifting linkage is different
      • RACR_73s
        • 879
        Don't forget about the difference in the input shafts...the Falcon is a 3pc. and your flex plate/starter ring setup or whatever you call it may not work with the Falson. I have a flex plate with the coupler built in and I can not use my Falcon with it so I had to go back to the stock starter setup. Hope this helped...good luck.
        • joeltjen
          • Jul 2010
          • 92
          buy the flywheel without the built-in hub (i think they're about $50) and use the rest of your falcon stuff and you can still use your reverse mount starter, bellhousing ect. i'm not sure but i think you can buy a falcon coupler with the drive for rear mount pumps
          • RACR_73s
            • 879
            Thanks, I am aware of that but do to time/money I went with what I had and it is working just fine. I was just trying to point out something before they got to far into it.
            • powerslide
              • 2696
              The main difference that will cause grief is the coupler arrangements. Falcon has the 3 piece and brinn is the standard output shaft and coupler. Make sure you get the coupler with the falcon
              • LateModel B23
                • Oct 2012
                • 283
                Thanks, found a good deal on a used Brinn. I will send the broken one in for a rebuild/repair.
