hi my question is how long do you normally run the lift bar spring before being replaced. Also do you thing if the spring goes soft would you lose your forward bite.
lift bar spring
Never had to replace one, We used Hypercoils and had one that was about 5-6yo and it rated right. But yes a very soft spring could limit forward drive but a typicl spring would have to loose a LOT of rate to cause the problem.Originally posted by 75t View Posthi my question is how long do you normally run the lift bar spring before being replaced. Also do you thing if the spring goes soft would you lose your forward bite.
