Bert 2nd gen problems
  • bigk44
    • Feb 2011
    • 67
    Having issues getting car to go in reverse. If I move linkage to go in reverse it will not go into low. I have the linkage straight going into the trans. Anyone else have these issue's? If so how did you fix it?
    Thanks,
    Kevin
  • lrnvlFan1w
    • Apr 2009
    • 58
    Thanks,
    Kevin
    We had an issue where we had no 2nd or reverse and the shifter fork was broken.
    • JustAddDirt
      • 1893
      bert
      unhook shifter.
      put in reverse manually by pulling shift lever all the way out. that should be reverse. start car and see if it engages. if so proceed to below about grinding .
      Low and Reverse are very close together.
      I had to grind a little bit of the shifter lever out were it hit the mount were it mounts to k0ckpit.
      did not have enough travel to go into reverse, and high, no matter how much I adjusted the length of rod.
      • bigk44
        • Feb 2011
        • 67
        Originally posted by JustAddDirt View Post
        unhook shifter.
        It goes in if you manually do it but shifter does not work. I was thinking the same thing as you are saying. How ever I was thinking of putting a spacer on the linkage to avoid grinding the shifter. Am I thinking correctly on this?
        • JustAddDirt
          • 1893
          you could do that, or drill another hole a little higher up on the shifter, that will let the shifter have more throw.
