Has anyone ever just used a chain on the brake side of the liftbar...our track days its illegal to have a spring and the rubber bumpers don't seem to be very consistent
6th coil
Chain if fine, and its easier to set pinion angle with a chain, might can add a little rebound to 5th shock, just to slow it down a little.
Depends on how hard you brake (or let the back pressure from the motor "brake") on entry.Originally posted by junebug View Postmy car is awfully tight in now...but are we talking erratic loose or just rotate better off throttle
The idea of the 6th coil is that it keeps the rear wheels from becoming suddenly unloaded during decel. When it his the chain with no spring, it will unload all at once. This is why someone else mentioned more rebound on your 5th coil. You'll want to SLOW that process down.
Or...you might like it...only one way to find out.
