what type of track conditions would it make sense to put a dummy shock in front of the LR? We currently run a gas pop up shock on the LR front but have the dummy shock and wonder when to use it.
dummy shock
Usually hooked up heavy rough tracks don't need the pop up on the lr, if you limit travel with a chain on the lr then there would be no use for a dummy shock at all .
look up Mark Bush Racing and call mark himself, he can give you the best answer, I run gas pop up on slick, stop and go tracks, and a standard oil afco 6-0 in the tacky, both with the chain
