anyone every used rear 88 hoosiers on the front i have some 21s and cant run them on rear due to 55 rule and was wondering if anyone ever tried them on the front
tires
if you can get them up to around 88-89 inchs roll out there wouldnt be any problem. but if they roll out diff than the tires your currently running it will change your car alittle bit and make it drive alittle different
Shorter sidewalls make the car more responsive to you turning the steering wheel. Watch for ground clearance changes as previously mentioned. I used to use Hoosier LSBs measuring 89 inches all the time.Modern Day Spec Wedge Racing
