604 Mid Plate
  • jarocket7j
    • May 2013
    • 2
    604 Mid Plate
    We are running the 604 with the mid plate in the position putting the engine as low as possible. What would raising the help or hurt?
  • Egoracing
    • 4852
    With a steel block motor you should be using 1 inch spacers under the motor mounts and then setting the angle with the mid plate, Some are one hole up and some are 2 holes up to get it set right. To low and you will hit the oil pan and damage it and raising it helps the car roll over to the right front.
