heavy steering after rack swap
  • rubbinsracin
    • Aug 2009
    • 668
    so we swapped out our rack after a nasty wreck Saturday put new fluid in it and the steering is very heavy. Will the car need to run for a while to bleed out the air to allow the steering to become easier?
  • big88fan
    • Feb 2010
    • 386
    No it shouldn't, you have something bound up somewhere or the ps pump quit I have had the kse tandem style do that after hard wheel contact.
    • merc123
      • 1261
      Is the servo the same?
      Web: http://www.t17.co
      • rubbinsracin
        • Aug 2009
        • 668
        Yes servo is the same. It is a remote servo style not an incorporated style. Gonna jack it up tomorrow and check for any binding and try to get any bubbles out that could be there.
        • rubbinsracin
          • Aug 2009
          • 668
          we think we figured it out. on the top side of the rack there is an adjuster that puts pressure on the steering shaft. we over tightened it. backed it out a half turn or so and the rack is better than new.
          • rubbinsracin
            • Aug 2009
            • 668
            well turns out that didnt fix it. rack turns fine now when the car is shut off, but after you start it up. rack is almost impossible to turn. hoses are on correctly. tested the pump and it is working. are there any valves in the rack itself that could be causing the problem?
            • Egoracing
              • 4852
              Could be an O ring in the slave cylinder.
