When updating a 07 smack to a gen x does the lower a-frame hook up points change and does the right front rail have to be raised or is it already raised on the 07. I see that the upper hook up points are not even close to the same but not sure about the lowers. Are any of you guys running the smack rear with the gen x frontend and doing well with it . Thanks for any help
07 mastersbilt
mastersbilt
Just got off the phone with mastersbilt and they said theres no update for a 07 or any other smack to a gen x. There two total different animals.Originally posted by 01_4_life View PostWhen updating a 07 smack to a gen x does the lower a-frame hook up points change and does the right front rail have to be raised or is it already raised on the 07. I see that the upper hook up points are not even close to the same but not sure about the lowers. Are any of you guys running the smack rear with the gen x frontend and doing well with it . Thanks for any help
You can update an 07 smack to the S7 front end. This is just different spindles, control arms, and tie rods on the right side and different spindle on the left side. Chassis pickup points are the same.
Some people think that this is GenX front end on a smack car but it isn't.
